- 13 Dec 2010
Hey guys,
Here's my computer specs,
Motherboard: MSI Z68-GD65 (G3)
Motherboard Driver: All up to date drivers
Motherboard Chipset: Z68
Motherboard BIOS: E7681IMS V23.6
CPU: Intel Core i5 2500K OEM
Memory: Corsair XMS3 4GB (2x2GB) 1600MHz
Memory Latency: 9-9-9-24
PSU: OCZ Stealth Xtreme 2 700W
Graphics: MSI N560GTX TI Twin Frozr II OC Edition
Graphics Driver: 290.53 Beta driver
Sound Card: Asus Xonar DG
Sound Driver: Version: 7.12.8.1794
Operating system: Windows 7 64Bit
I've sent the Overclockers tech support a web note and they suggested i posted in this part of the forum to see if i cant get any help here first, here's the problem i sent them...
I had the system put together and running fine just before the new year. Once all the drivers and bios had been up dated I went into the bios to change the speed of the ram to run at 1600MHz and set the voltage to 1.507v. That was the only settings I had changed and all was running fine for aprox 3 to 4 weeks. A couple of days ago 19/01/12, I decided to start overclocking. I was doing this by just increasing the multiplier in the bios by a little at a time and testing using IBT and Prim95. I got to a multiplier of 43 and it passed the stress tests but when I change the multiplier to 44 and clicked save changes and reboot the system failed to reboot and got stuck in a boot loop until it finally booted displaying the message that the ocing had failed. I pressed F2 to restore default setting and continue. The system then booted into windows. I then shut down the system and a minute or so powered back on, it powered on for a couple of seconds then turned off then a couple more seconds later it turned back on and continued to boot into windows. Ever since then when ever the system is turned on it does that double boot and I am unable to try any ocing as it always fails. Also when I click the option for spread spectrum in the overclocking setting and choose disable the system locks up and is stuck on the bios screen, only way to get out is press the reset button on the motherboard. I have tried different bios versions as advised from the MSI HQ forum and using their flashing tool. The same problem happens with any of the bios versions. At the moment I have the system running on a bench setup with only the ram, processor and cpu attached.
If anyone has any help with this matter i would really appreciate it as at the moment my system i kind of useless as i want to oc but cant. I'm not sure if this breaks forum rules but this is a link to my thread on the MSI HQ users form explaining my problem and things that have been suggested i try and have tried with no luck.
Also on sunday windows decided that it needed to be authenticated again but i just clicked the ask later option and later in the day it decided it was an authentic copy, it has now done this again this morning and i can't figure out why it's doing that now as well.
Cheers
Alex.
Cheers
Alex.
