Anyone had this xbox360 problem.
Caporegime
27 Nov 2005
Guernsey
This has happened to me a few times when i have left my xbox360 doing nothing but just sitting on the dashboard screen for a few hours..
Has anyone else had this problem.
I have not had that problem. I would consider getting it replaced though if I bought a graphics card that did that I would consider it borked so I would only assume the same for a 360.
As above, its the box and not the cable Id be very tempted to send it back.
Just noticed chap that youve only got 3 stars, will set you as preferred to try to get it a bit higher :)
3 stars :confused: I don't even what know there for yet...
Refers to your player rating, your reputation. If people set you are preferred, your stars increase. Doesnt do anything, but its nicer to have 5 stars :D
Thanks for the replys guys...
Plus i think i need to try put in a bit more play time to try and get my gamerscore up a little more..
Hi mate,
ive had this happen once or twice very very rarely to be honest i dont think its anything to worry about unless it gets more frequent. In fact it never used to do it before the last firmware update :( But like i say i think its only done it the twice and ive had the machine since release day.
Cheers,
Hugest
