Using a wok or frying pan to cook it up, you will need:
1 punnet of pomodorino cherry tomatos
1 green pepper
1 yellow pepper
1 onion
1 clove garlic
3 green/red chillies or combine if you prefer
chives
Salt
Pepper
Heat some oil in a pan (I use chilli oil), finely chop the peppers+onions and put them into the pan, lightly fry while moving them all the time while they sweat (dont have the pan too hot or allow the mix to brown)**
Finely slice the chillies and add them to the pan (with seeds if you can handle the heat) - next, half the tomatoes and add them, again making sure the pan is not too hot, you don't want to burn anythin - if any of the mix is sticking to the pan - it's too hot - next, finely slice or chop the garlic and add this - using scissors, cut the chives over the pan into the mix, stir them in...add salt and ground pepper...the pan should be on the heat, in total from the time you start for about 20 minutes.
Enjoy
