Anyone have the Thermaltake Armor Jr? A few questions..
Hmm. Because my desk has like a dedicated tower space, but it measures exactly 47cm. I'm 0.8cm short! lol. I was hoping that I could take the feet off to to fit it in. You can take them off, right?
That case is sooo cool lol.
-Phæte
Hi
I might be wrong but i'v got a ThermalTake Soprano and it looks like it have the same feet. The feet can Fold in so you can have them in or out. ;)
Do you mean fold in horizontally or vertically? Because unless I can make the tower shorter in height, it won't fit into my desk. :(
Is there any way you can remove the feet at all?
-Phæte
-Phæte
i dont think so m8 atleast u couldnt on my normal sized armor
mk17 said:
46.5mm without feet, 48mm with them. hth.
[edit] you can remove the feet, btw[/edit]
Cheers! I was hoping someone would say that so I could ignore the other posts. ;)
It better fit into my desk otherwise I'm gonna have to unleash a can of whoopass on it. That, or stick it away from my desk so it looks like a loner.
Was considering buying one, but the armour has droppped in price (£93 for black) and i know where to get silver for £95ish (inc vat) so i decided to go for that or a Lian Li and do a window mod myself.
My friends got a Armour Jr, all i can say is they are very well built look amazing and deliver good cooling. Rofl @ the height :p
isnt it just an inch or so of the normal sized armor, cant se how it has a Jr name
