Formac Gallery Xtreme 2010 20.1" TFT 12ms 700:1 (1600x1200) (DVI) Monitor
never even heard of this before are they any good ,really looking for an 20 if poss which is the best for under £400 only for gaming really thanks
You would be better off with a widescreen, there are load for under £400 and one for under £300. The spec isnt bad on that but you can get the Philips 20.1 inch widescreen for the same price and it has better response time etc. Also looks much nicer
