- 25 May 2011
I own these glasses
https://imgur.com/xAzAEVV
If you haven't seen them before
http://wearality.com
The headset strap and how these have been made is a nightmare for comfort and immersion it constantly wobbles when you move your head.. Great lenses though and better than rift and vive imo
I'm looking to buy a not to expensive vr mobile headset that would fit my Samsung s8+ mobile and basically remove then lenses and fit the wearality lenses inside.
Can anyone recommend any headsets? With large-ish face area to fit these larger than lenses in?
I plan to use riftcat to stream steamvr to my mobile and I plan to setup ps move controllers with tracking - I all ready know how to do this
I think I can better the vive and rift regards picture quality but best of all there wont be cables
Any help is appreciated
