Anyone here using QSC amps?
Maybe a bit overkill for home use I think. Arn't these what hippies use in fields to run their turbosound bins off?
What you looking to power with it?
Extreme over kill for home use, I'm looking into building my own PA soundsystem... This is the closest section on OCUK, as there isn't a Pro-sound section on here... And I thought "sound city" wouldn't be relevant at all as it's more about computer speakers... ;)
I do plan to power 4 horn type subwoofers with it, admittedly it's overkill, each driver is rated for 600Wrms, but I'll be using a limiter so I don't cook my voicecoils... but this thing appears to offer so much power I could power subs from 1 channel, and tops from the other (in mono admittedly)...
I was just wondering what QSC are like in terms of build quality and warranty, as it does seem amazing something less than 15Kg can produce so much power!
