Anyone know about washing machines? (Fault?)
23 Mar 2011
Hi!
We recently moved in to our first house so all this is quite new to me, we got a 2nd hand machine to keep costs down
Anyways, we always use the same cycle for our stuff but lately it takes half an hour one day and as we speak the current cycle has been over an hour?it seems to stop and start over and over again, and all seems very random
Is it faulty or are we doing it wrong?
Its an indesit machine
I would have thought the same program should be the same each time
Thanks
If you aren't over-loading it, it's probably faulty. Indesit have produced some poor machines.
Its a bit confusing, dont wanna buy a new one if we dont have to, the cycle has stopped now, took about an hour and a half
Different programs take different amount of times to complete. Different brands also work differently when it comes to the final spin.
Some simple tests you can do to check if the machine is mechanically sound.
Does it fill?
Does the drum turn?
Does it heat?
Does it empty?
If it does all of those then mechanically all of its functions are working.
After that you are looking at a control issue.
Modern machines have what is known as out of balance controls, these were introduced basically to stop the machine tearing itself to bits on the final spin.
People think that over loading a machine is bad, it isn't really, the issue with over loading is that your clothes will not come out clean as they can't move around in the drum.
Under loading causes more problems, with bigger drum sizes today you need to put more in them to get them to spin. What happens with the out of balance controls is the machine can detect when the weight of the load is not evenly distributed around the drum, if this happens the machine will not spin.
If it's the same cycle every time, and it takes half an hour one day, then it MUST be a fast wash (30min)
If a fast wash takes over an hour, and it's an indesit, i'd bet money on it being a faulty control panel/timer
Is it one of those load detecting cycles that detects the weight of the load and tries to balance out the drum?
If so the machine could be struggling to spin because it cant manage to get the load to even out.
possibly causes for that are if everything was chucked in bunched up or theres not a big enough load
What's wrong with Indesit? Had mine for 3 years now and it's going strong.
*awaits it to implode now I've said this* :D
White goods snobs brah
If its not meile or lg direct drive then you are classed as a benefits scrounger you thieving scum!
dole scrounging ***** get a 1500 quid washing machine you scum
bet its some kind of council package washing machine and the rest oh his furniture as well!
some of us with jobs wish we could sit timing how long our washing machine takes to complete a cycle but we have to work for a living so don't have that luxury !
If it counts for anything, our 4 1/2 year old Indesit tumble drier munched it rear bearing this week! Back to drying nappies on the radiators again!
indesit love to munch the bearings or wear the motor brushes.
Anyone have an indesit washing machine that doesn't have a pile of carbon dust under it from the brushes ? :D
