18 Oct 2008 at 16:08 #1 thepharcyde thepharcyde Soldato Joined 17 Mar 2004 Posts 8,259 BMW own brand blue/green stuff. What's the coolant/water mix, not written on bottle? For a M54 3.0l Thx
18 Oct 2008 at 16:14 #2 loltim loltim Soldato Joined 21 Oct 2002 Posts 14,595 Location Wellington, NZ BMW stuff doesn't come pre-mixed?
18 Oct 2008 at 17:27 #3 Finglonga Finglonga Associate Joined 20 Aug 2008 Posts 1,948 Location Stafford If it's called coolant its already mixed, otherwise it would be called anti-freeze then it would be 50/50.
18 Oct 2008 at 17:28 #4 Clarkey Clarkey Soldato Joined 18 Oct 2002 Posts 18,301 nm Last edited: 18 Oct 2008
18 Oct 2008 at 22:41 #5 JamesRJ JamesRJ Associate Joined 9 Dec 2002 Posts 1,566 Location Somerset 50/50 is the the recommended mix for most anti freeze/summer coolant
18 Oct 2008 at 22:48 #6 [TW]Fox [TW]Fox Man of Honour Joined 17 Oct 2002 Posts 160,150 I'm pretty sure it's 50/50 if it isn't already premixed.
18 Oct 2008 at 23:23 #7 ShakenNstirred ShakenNstirred Soldato Joined 5 Jun 2003 Posts 8,732 Location sawley/ long eaton yeah premixed is 50/50 if u mix your own that should also be 50/50
19 Oct 2008 at 10:44 #8 thepharcyde thepharcyde Soldato OP Joined 17 Mar 2004 Posts 8,259 Cheers all sorted.
19 Oct 2008 at 14:26 #9 Sam Sam Soldato Joined 12 Jan 2003 Posts 14,488 Location Surrey As above 50/50 in the VX
19 Oct 2008 at 14:29 #10 Dogbreath Dogbreath Soldato Joined 18 Oct 2002 Posts 16,660 Location Devon ShakenNstirred said: yeah premixed is 50/50 Click to expand... The clue is in the name, you don't add water to premixed coolant!
