Scam said:May i be so bold as to ask why you rendered at 60fps? That must have taken a long time!
Scam said:Yup you need to make sure you have Vide for Windows selected. May i be so bold as to ask why you rendered at 60fps? That must have taken a long time!
binaryknight said:im guessing for smooth playback on intended format of pc
tv = interlaced so 25interlaced frames look as smooth as 50 non interlaced
pc is progressive so 25fps looks not that great and the reason for using 60 is probably to match the 60hz used by the screen mode of a lot of games.
Scam said:But if you're using non-interlaced theres really no need to go to 60fps. IMO 30p is perfectly adequate for a smooth video, regardless of where you're playing it. Would have saved a lot of rendering time as well!
