I don't think it is all that easy to do, because most laptops use LVDS panels or smart panel, which connect directly to the motherboard and does not need any conversion of the VGA signal, whereas normal TFT monitors use a panel connected through an A/D board which converts the VGA signal into something the panel can understand.
What is the model number of the panel?
