anyone know sql? i need to disconnect users
5 Jun 2005
Southampton
im trying to upgrade a database remotely and some silly bugger is logged in. i have a tool that we use for this purpose however its not working, i need to kill the connections to the database but cant seem to see it.
using sql standard 2008
May be better posting this in HTML, Graphics & Programming, those guys know their SQL.
Right click the database and go to properties. Then go to the options section and at the bottom set restrict access to single_user; it'll kill all connections apart from yours. Set it back to multi_user when you're all done (if it doesn't do it automatically).
thank you. is this in Studio management?
By the way you can view a list of connections by running:
exec sp_who2
most of the 'sa' users will be SQL its self rather than people on your system.
You can kill a specific session by running:
kill <spid> (which you can read from the first column of sp_who2)
