Anyone know where I could get an OZ Wheels Fitting Kit?
Caporegime
8 Mar 2007
Surrey
As above, anyone know where they are available? Found one site online that sells them, but the website is broken.
Fitting kit as it bloody expensive rip off money grabbing OZ fitting kit.
Its 4 spigots for after market alloys to fit whatever size you need, but they are proprietary OZ only spigots, only available from OZ, and only available as part of a 'Fitting Kit' that includes 16 or 20 wheel bolts and some stickers.
OZ F1 Cup wheels, and they need to fit 60.1mm Renault hubs.
Just need to find a distributor whos website isn't broke and who answers emails.
Are they not 60.1 bore then? You is needer some spigot rings if they aren't
Nope, they are aftermarket multifit ones, not the Renault branded ones from the earlier Clio, and OZ wheels use OZ only spigot rings, so no other ones fit (I have both a plastic and a metal set).
They are the same as those ones you bought that were cracked. If they were multifit aftermarket ones like mine then I would say you dodged a bullet.
Try and blag halfords.
I went in about 5 years ago and said I bought some TD Pro Race 1's from them but they didn't supply a fitting kit, they went out back, came back and handed me a fitting kit with no questions! Centre caps, spiggots and 16 bolts!
Halfords will probably be able to order them in for you, however you might as well try the UK arm of OZ wheels (more a distributor really...):
O.Z. RACING LTD UK & IRELAND
Lowfields Way
Lowfields Business Park
West Yorkshire HX5 9DA
Elland
UK
Phone: +44 (0) 8454379905
Fax: +44 (0) 8454379906
Email: [email protected]
Have you tried phoning the people with the broken websites? Probably get a proper response then.
Lowfields Way
Elland
UK
Cheers, I'll give them a bell.
I have a brand new and unused set from my 17" Superleggeras, though I'm not sure what size they are. Can check tomorrow if there's a chance they'll be of use.
I need ones to fit 60.1mm hubs (Renault). Thanks
Have done, they need to talk to OZ and will get back to me.
Managed to get one from Ronnie Cowan (http://www.ronniecowan.co.uk/)
Dropped him an email and he has got hold of OZ and found they have a kit (all be it in Italy!) and arranged for it to be couriered to me for £48. Cheaper than most other places who have them listed, and direct from OZ too.
Really nice guy too. If anyone else has a similar issue in the future definitely give him a call.
Anyone need some wheel bolts? I have 16 on the way to me now that I wont need :)
