Anyone own a Samsung HT-C555 system?
26 Nov 2002
Romford
I bought one of these the other day, but I'm awaiting cables to get it properly setup.
I had a quick fiddle and when I plugged in the HDMI, the TV (Panasonic X20) decided to send it's audio back down into the DVD player, I presume using the Audio Return channel, but there's no mention of ARC on the Samsung specs, so I'm a little curious.
It'll be good if it does support ARC, but I didnt have any speakers attached so I had no idea if it was working. Does anyone own one of these systems?
My advice was going to be "Don't do it, get an Onkyo instead".
It should be able to do the TV audio via HDMI, yes; I'm fairly sure my previous Samsung one did.
Would it also do the HDMI1 (media Center) and pass that back down HDMI2? Saving me the spdif between PC and DVD?
Having wired everything up, it doesnt seem to have ARC, so I run an optical cable from the TV back to the DVD receiver. This works fine, but only 2.1 - If I bought a Radeon 5450 for my media center, would this send 5.1 up the HDMI and out the TV's optical, or will my TV just mix it down to 2.1?
