It's not uncommon - the way around it is to set the monitor to just outside the "buzz threshold", and then do any display tweaks in the display options for your graphics card.
I'm down to a single screen now, a Dell 2405FPW, which buzzes above 50 brightness, it's a shame that after 5 years they're still suffering from this issue!
I'd love to fix the buzzing on my Dell, I just need to find out what is causing thee buzzing. It's most likely the backlit inverter...
No idea on a Mac, but on W7 just head to the properties section of your gfx card (nVidia control panel or aTi CCC) and under one of the tabs there you can alter colour balance, brightness, contrast etc.
All that will do is dull or wash out the image - it doesn't actually change the intensity of the backlight. You could give it a go but I don't think you'll like the results.
To clarify, you do this part AFTER you have used the physical controls on the monitor to set it just outside the point where it buzzes. You're then using your graphics card to compensate back to the image you want.
Ok, I did try reducing the brightness in the Nvidia control panel and upping the brightness on the monitor, and while the buzzing noise did vanish, the picture didn't look good and also my Mac is now blindingly bright.
The fact that it is more than one brand is rather annoying, if there was a particular brand that was known to make quiet screens then I'd choose that over Dell/Samsung/etc.
I do hear these newer LED screens are much quieter however, I guess the fact that these LED backlit screens do not have a high voltage high frequency CCFL inverter means that it's most likely to be the backlight inverter that is making this annoying noise.
Well, it did sort of work, but I'd really like to find some way of fixing the monitor really so I can use the lower brightness settings without the buzzing...
If I get some time I think may have a look at the backlight inverter.... I'm 99% sure it's that is buzzing.
