30 Nov 2006 at 15:27 #1 Nor Nor Associate Joined 27 May 2003 Posts 1,861 Can you tell me where the hazard switch is on a 2003 models? Cheers in avance.
30 Nov 2006 at 15:39 #2 tblocksom tblocksom Associate Joined 23 Oct 2002 Posts 345 On a 2000 model it is above your rear view mirror in the roof pod. HTH, somewhat.
30 Nov 2006 at 15:41 #3 Nor Nor Associate OP Joined 27 May 2003 Posts 1,861 Cheers mate. Someone else has said it's at the left hand side of the gear stick, so that gives them 2 places to try Thanks.
30 Nov 2006 at 16:05 #4 D4VE D4VE Soldato Joined 23 Oct 2003 Posts 8,899 Location Hampshire, UK Its got a big red triangle on it, should be quite easy to find.
30 Nov 2006 at 16:46 #5 Nor Nor Associate OP Joined 27 May 2003 Posts 1,861 D4VE said: Its got a big red triangle on it, should be quite easy to find. Click to expand... You'd think
30 Nov 2006 at 19:32 #6 tblocksom tblocksom Associate Joined 23 Oct 2002 Posts 345 Nor said: Cheers mate. Someone else has said it's at the left hand side of the gear stick, so that gives them 2 places to try Thanks. Click to expand... Not on a 2000 model
30 Nov 2006 at 22:16 #7 SoliD SoliD Soldato Joined 25 Feb 2004 Posts 18,497 Location Hampshire er in ours it is above the rear view mirror. on the light pod. 2002 model though.
