Anyone Read Dump Files?
29 Sep 2004
Wilt of the Shire
Since installing my Asus P6X57D-E board last week I am having constant BSOD and Event Viewer just shows as kernel-power event id 41. Thinking I'd botched up my install I re-installed Win 7x64 last night and I'm still getting the error now. It must have something to do with sleep mode cos that's when the problem is occurring, when the pc wakes. All the drivers are the latest ones for the board and all my kit too.
I have a dump file zipped up so if anyone can read it for me and see what's causing the problem it would be greatly appreciated (can I attach a zip file to a post?). If it continues I'll just stick my Asus P6T Deluxe back in cos I never had any problems with that board.
I can, send it to the email in my sig or upload it and post it here so others can have a look too.
You'd have to upload it to your webspace/megaupload or somewhere.
Here's your dump:
PHP:
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [082510-8704-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*c:\temp\symbols\*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02c14000 PsLoadedModuleList = 0xfffff800`02e51e50
Debug session time: Wed Aug 25 19:02:30.973 2010 (GMT+1)
System Uptime: 0 days 1:41:02.004
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck F4, {3, fffffa8008b2e410, fffffa8008b2e6f0, fffff80002f8f5d0}
Probably caused by : hardware_disk
Followup: MachineOwner
6: kd> !analyze -v
CRITICAL_OBJECT_TERMINATION (f4)
A process or thread crucial to system operation has unexpectedly exited or been
terminated.
Several processes and threads are necessary for the operation of the
system; when they are terminated (for any reason), the system can no
longer function.
Arguments:
Arg1: 0000000000000003, Process
Arg2: fffffa8008b2e410, Terminating object
Arg3: fffffa8008b2e6f0, Process image file name
Arg4: fffff80002f8f5d0, Explanatory message (ascii)
Debugging Details:
PROCESS_OBJECT: fffffa8008b2e410
IMAGE_NAME:  hardware_disk
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAULTING_MODULE: 0000000000000000
PROCESS_NAME:  csrss.exe
EXCEPTION_RECORD:  fffff88006d8cb78 -- (.exr 0xfffff88006d8cb78)
ExceptionAddress: 0000000077c05a26
   ExceptionCode: c0000006 (In-page I/O error)
  ExceptionFlags: 00000000
NumberParameters: 3
   Parameter[0]: 0000000000000000
   Parameter[1]: 0000000077ad599b
   Parameter[2]: 00000000c000000e
Inpage operation failed at 0000000077ad599b, due to I/O error 00000000c000000e
EXCEPTION_CODE: (NTSTATUS) 0xc0000006 - The instruction at 0x%p referenced memory at 0x%p. The required data was not placed into memory because of an I/O error status of 0x%x.
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000006 - The instruction at 0x%p referenced memory at 0x%p. The required data was not placed into memory because of an I/O error status of 0x%x.
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  0000000077ad599b
EXCEPTION_PARAMETER3:  00000000c000000e
IO_ERROR: (NTSTATUS) 0xc000000e - A device which does not exist was specified.
EXCEPTION_STR:  0xc0000006_c000000e
FAULTING_IP:
+23a
00000000`77c05a26 ??              ???
BUGCHECK_STR:  0xF4_IOERR_C000000E
FOLLOWUP_IP:
+23a
00000000`77ad599b ??              ???
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: hardware_disk
STACK_COMMAND:  kb
FAILURE_BUCKET_ID:  X64_0xF4_IOERR_C000000E_IMAGE_hardware_disk
I've never seen this error before, but "Probably caused by : hardware_disk" sounds like your hard disk could be failing. Have a look at the hard drive manufacturer's website for a diagnostic tool to check how healthy your drive is (most of them should have one).
How are your drives connected, IDA or SATA? Try replacing/reseating the cable just incase.
A repair on the hard drive might be a good idea too, open up an elevated command prompt (start > type cmd then press ctrl+shift+enter to run it as an administrator) and type:
chkdsk /r c:
It will reboot your computer and check the Windows file system is ok. It might take an hour or so depending on how big your drive is.
Whether or not it's the hard disk, take a backup of your files as a precaution either way.
Here's your dump:
PHP:
Machine Name:
6: kd> !analyze -v
terminated.
longer function.
Arguments:
Debugging Details:
NumberParameters: 3
CURRENT_IRQL:  0
FAULTING_IP:
+23a
FOLLOWUP_IP:
+23a
STACK_COMMAND:  kb
chkdsk /r c:
Thanks for taking the time to have a look at this. I have a brand new Crucial C300 64GB SSD which is connected to the Marvell 6GB SATA slot on my board. I also have a G Skill Falcon 128 GB SSD which I now use for games etc and a normal 500 GB HDD. I'll check the connections and also get the diagnostic tools for the drives. I'll let you know how I get on!
I was searching for the error and came across this - is your main HD plugged into the first SATA channel?
When you installed the new mobo did you reinstall Windows?
Yes I always do that when I change a board. Installed it twice now and still the same.
PHO - The board has 2 SATA 6GB connections and the drive is plugged into the top one which I assume is SATA 1. The connections are listed as SATA 1 & SATA 2 but as they are the angled connections I'm never sure if 1 is the top or bottom! I'll try the bottom connection when I get home from work and see what that does.
Ok cool, just checking it wasnt some driver mismatch in Windows.
Best bet is to try Pho suggestion and report back then. After that maybe try a different SATA cable.
