Anyone recomend...
8 Aug 2007
North West
Has anyone used/can recomend some sound dapening material?
It seems fairly cheap so I might give it a go.
Is it worthwhile? Will it raise my temps a lot etc :confused:
Actually I used it on 2 different cases... but never really heard any difference :/ not sure if I did it right though since bth cases had a side window and I could only place the foam on the bottom and top panels...
I wouldn't bother.. I would look at replacing the two 12cm fans that come with Antec 300 as they are rather noisy. Get some decent ones like Noctua.. Worth the investment.
You can then buy a decent fan controller, like the zalman, to reduce the the noise when the system is not under any load.
Would love one of those fan controllers but they've been OOS for ages :(
Already ordered some noctuas for the case, although the top fan is 140mm on the 300 (dont think noctua do a 140mm fan?)
I would recommend getting 2x Xigmatek 120mm and 1x Xigmatek 140mm. They dont sell them here at ocuk but well worth getting.
