Note, not the same idea as parallel loops
It's not something I see done very often. It makes the tubing more complicated, and care must me taken or you end up starving parts of the loop of water since the current is stronger through the path of least resistance. However it decreases load on the pump, and not everything needs the full flow rate over it. So it is possible to gain higher flow rate through radiators and cpu block at the expense of flow rate elsewhere.
Even if perfectly balanced, you are splitting the flow of coolant which (probably) leads to less pressure in each arm and worse cooling. Flowrate decreases as well, which probably means putting radiators in parallel is a bad idea.
Sli graphics card blocks are almost designed for this. With inlet top left and outlet bottom right, connecting each card to the next with two tubes instead of one gets you a series of parallel sections of exactly equal resistance. I'm sure this will work well, and have seen a couple of photos of people doing just this.
Less simple would be splitting the loop so one arm goes through northbridge and the other through mosfets, which I think can be achieved but may need either care or testing.
So, introduction over, does anyone do this? I've asked thermochill to machine some Y pieces, but it's possible the lab at uni can do this as well.
