Anyone running a pfsense VM on Ubuntu with KVM for virtualisation ?
18 Oct 2002
If so, what config do you run for network cards.
I've got the WAN interface as a card with two ports on, PCI pass through etc, and the LAN interface as a virtual one that is a tap on the bridge of eth0 (my onboard Ethernet port.
Regardless which virtual adapter I use (Virtio, Rtk, or e1000) I can't seem to get more than 20mbit down through the port.
If I swap to the other Ethernet port that has the WAN port on, I'm back at 50-60mbit.
Anyone got the slightest idea what I can do ?
So there is clearly something mad going on. I'd already seen those links, but thanks.
I put the iperf package on pfsense and ran some tests.
Host Machine to any of my other VMs running the same E1000 virtual network adapter - 1GBps in either direction
Host machine or any other VM to the pfsense VM - 150 ish mbits
So... I made use of the other physical port on the card to see what happened (its a HP card, Broadcom Extreme chipset) - 40-60mbits?!?!?
At a total lost as to what I must have wrong here.
