Hey guys,
I love my V600 case, but its a bit loud. Ive ordered a Zalman for on the cpu (hopefully it fits) but its still a bit loud over all. There is also a Zalman on the gpu, and a Tagan psu, so im guessing its down to the case fans/case.
Before I lay out £40 or so for new fans and acoustic matting stuff, do you think its worth it? Theres a lot of holes in this case, which I wouldnt want to block with the matting too much, so I guess thats where the soun is coming out. So before I buy that stuff, which is equal to half a new case, do you think its worth it?
If any of you can comment on how you sorted out noise in your V series case, that would be appreciated
By the way, all fans are currently on 7V.
