Anyone still running a titan x pascal
27 Dec 2003
Anyone still using one of these cards and if so do you have it hooked up with one of the latest ryzen chips?
I still have my 4790k @ 4.7Ghz but want to finally upgrade to ryzen probably a 3900x.
Don't see point in changing the gpu as its still a beast today
Both are under water btw
I'm pondering the same upgrade but am struggling to see the value given a new CPU,Board & RAM are needed (I'm running a 4790K @4.8 but with a Zotac 1080ti Amp Extreme @4K, my CPU is water-cooled but not the GPU), probably will go down the Ryzen route but minded to wait for a bigger boost over what I currently have.....
I upgraded from 6700K @4.6 to 3700X just to have more cores so I can run some programs alongside games without any performance hit.
Went from a 4770k @ 4.5 to a 8700k and kept my titan X Pascal and honestly I'm looking at switching CPU before upgrading the GPU. It's still doing a fine job at 1440p 144Hz
I did a few benchmarks with 6800k and 8700k both over clocked same core count and there definitely was an ipc increase as fps went up overall in all games
