- 13 Apr 2013
- La France
I've been getting a lot of eye strain over the last couple of months with my +1.25 reading glasses (use them for all close / computer work - 7+ hours a day), so I went to the local opticians who pointed out I'd had these lenses for 5+ years and I now needed +2.0 lenses.
So far, so good. As my previous pair had a good depth of focus, they were great at normal reading and computer display distance.
Talking things over with the optician, I decided to go for a pair of what's called "computer/occupational" lenses where you get the full +2.0 in a central "sweet spot" which then tails off towards the edges of the lenses so you can focus on displays etc. out to and beyond arm's reach.
These are working fine at close range, but I'm finding that not having the whole of my 27" computer display is very annoying and causes near-constant head movement.
Has anyone else used similar lenses and, if so, how long did it take you to adjust to using them?
I'm on my second full work day using them and am really struggling.
