Anyone Tried Re-attaching a IHS?
4 Aug 2005
Hi guys i haven't yet taken the IHS off my cpu but was curious in doing so (i like fiddling :p ), but just incase i cocked something up and temps wern't as i expected is it possible to re-attach it? has anyone done this or know if it is possible?
yea, its pretty easy to do.
Lining up the IHS is tricky though, esp as i like to make sure it has a good contact by putting it under a heatsink which tends to move te IHS slightly
Tom
i have used it without a IHS as i had an opty with badcontact and the load temps were 60 :eek: without the IHS they came down to 35.
reattached you can get the same 35-37 sort of figures with a good attachment
