Been looking at getting some of these a s my wireless doesn't seem up to much.
Has anyone got any experience with them
many thanks
Bren
Code:
Product Overview:
The HomePlug plugs directly into a standard 3 pin UK power socket.
The supplied Ethernet cable connects between the HomePlug
and the required network device.
Data is transferred between HomePlug devices at a maximum rate of 85Mbps.
The included software enables you to change the encryption password
of the device
and displays connection speeds between devices on the network.
Works straight out of the box - no drivers required.
HomePlug V1.0 specification compliant for interoperability
with other HomePlug V1.0 compliant devices
many thanks
Bren
