Anyone used Concrete Dye?
1 Jul 2003
There's a voice that keeps on calling me.
Hey folks,
Ive got a crappy bit of concrete patio that is a horrible boring grey, its around a 10m x 5m area. Ive been umming and aahing about slabbing it, and then started wondering if any dyes were available for concrete.
The plan would be to fill in the cracks on the bad bit and then skim (right word?) the lot with a coloured concrete, this would save me a packet over slabbing and improve the garden no end.
Any thoughts? has anyone tried concrete dye? any tips on suppliers?
by dye do you mean a pigmented concrete?
iv done various trials on it, green/red/black/white/yellow/brown
Edit: O just googled it. I have never seen this dye before? the spray on stuff?
The problems with it is that the surface will most likely get concrete efflorescence and you'll need to clean it. happened on a lot of the samples I made.
also if the concrete is on the wet side or has WRA/plasticiser in it you will get colour bleed on the surface.
if you want funky concrete get exposed aggregate concrete with a pigment in it. choose the colour aggregate you want can get some really interesting combinations
