- 18 May 2010
Hi,
I've been looking at AIOs as I fancy a change from Air cooling, my case is a Meshify C and I have quite a long GPU and tall RAM so AIO fitment is an issue.
I could put up to a 360 in the front but I dont like the idea of heating up my GPU with CPU heat and I noticed some 120mm AIOs are quite thick, I realised I could mount it as intake at the front above the GPU so the CPU gets the best temps as intake and put a fan in the ceiling above it and link both fans to the CPU header so the warm air coming in get exhausted out the top
This means the GPU will still have its own 140mm intake fan in front of it at the bottom
Anyone ever done a setup like this? The Arctic Liquid Freezer 2 120 is 38mm thick so its quite a bit bigger than other 120mm AIOs, there isnt much info on it though, just one Youtube review where some guy replaced his Esports Duo with one and reported better temps but in a completely different case
CPU is a 2600X so not the most difficult to cool anyway (I know you're thinking just get a smal tower cooler but I want a change)
Failing that, anyone else with a Meshify C run an AIO with tall RAM or long GPU?
Cheers
Cheers
