Anyone using a 360 on an LG L194WT (suggestions welcome)
Hi there, I've seen this monitor for £140 inc vat from a competitor, and it seems like a very good deal.
There is only one old thread on it from what I found, and the only problem seems to be the technology it uses to acheive 2000:1 contrast ratio, which seems to cause some flickering etc, but with it off, is apparently 1000:1 and fine.
But I can't find anyone using one on a 360, I'm currently using a Philips 170X5 which is 4:3, and the LG is a fair bit wider, and just as high, but the 170X5 two speakers built in at the bottom, which makes it quite a bit higher, and the bezel looks a little bit wider all round, so it should be a pretty good size upgrade.
So if anyone has this monitor, that'd be great.
Thanks
Edit:I have more spare cash than I thought, so any other suggestions for £250 or under would be appreciated as well.
Thanks
