One of these. I'm currently using a Netgear FVS338 which I've had for a long long time and it's been great, but I'll be upgrading to 120mb/s cable soon (from 50mb/s) and it's WAN->LAN limit is about 65mb/s, so I need something with a bit more power and throughput.
From what I've read, the RV220W has plenty of power (good for ~700mb/s WAN->LAN) as well as supporting VLANs with separate DHCP pools (something the FVS338 doesn't do). There's also SSL VPN which is going to be useful. But apparently the web UI is a bit slow/clunky. I'm sure I can look past that if the feature set is solid and it's a reliable piece of kit.
Anyone got any experiences with this or similar? I was looking at some of the Netgear UTM boxes too but without the ongoing support/maintenance licence you don't even get firmware updates
Cheers
	Cheers
