Is anyone using a GB P35 DQ6 with E8500 and F7 BIOS?
My initial setup worked fine until I flashed the BIOS to F7, now it just power cycles and won't POST.
I've swapped an E6750 in and this POSTs fine. Updated the RAM settings manually, set CPU speed to auto and put the E8500 back in - still won't POST.
Is there anything that needs to be set in the BIOS for this to work, or is this looking to be a faulty CPU.
I had similar issues with a P5K board that wouldn't boot after a BIOS update.
