Anyone using an 8gb microSD with a HTC TyTn?
26 Mar 2007
Nottinghamshire
Thinking of buying one but the spec says it will only support 2gb. Anyone using an 8gb or even a 4gb without any issues?
Hes asking about the Tytn not the Tytn 2 (Vario 3)...
AFAIK Tytn only supports Micro SD and not Micro SDHC so that would mean you can only use upto 2Gb. But there are loads of non-standard compliant Micro SD cards out there that support over 2Gb though I dont know if they have issues or not...
ps3ud0 :cool:
