Anyone using catalyst 12.2 preview?
3 Oct 2009
I'm tempted to switch over to try out the new eyefinity taskbar, and game profile management, etc.
But since it's a preview I'm hesitating. Has anyone tried it? Any problems?
I'm using them. I believe PLP is not a feature, I could be wrong though. This is what i see under the new resolutions tab:
As for the new windows taskbar, it just allows you to have it on a single monitor instead of spread along all three (i had hoped it could be spread across two of the three).
And for profiles, the best solution by a huge margin is to use Radeon Pro, it will take AMD 10 years to advance it's game profiles to this level.
I went back to 12.1, when I installed 12.2 they wouldn't allow me to have my second monitor set to potrait mode!!
Hopefully something left out of the beta, which will be included in the full build!
RadeonPro is outstanding. The problem is, it isn't being supported anymore since the creator switched to an Nvidia graphic card. Some people are reporting incompatibilities with the newest games because it isn't being updated any more. CCC may not be as good, but it's the only way forward.
What does the application profiles tab look like?
Is it possible to set up a game profile that also activates a catalyst preset (like, switch eyefinity on when a game starts and off when it ends)?
Try unticking alternate dvi under my digital flat panels, that gave me back control of portait for all my screens.
Im using it for RAGE since it is the only way i could get it to run, works a treat though. A bargain for £10 delivered.
