Anyone using decent CSS3 effects?
21 Oct 2008
Mooching... in your house
Out of interest, is anyone really using things such as rounded corners and the like yet? I can't help but think whats the point since you'd have to make it degrade to an image based solution for IE and since that would work across the board why add the extra code to do it "properly"?
My hatred for IE is limitless.
I do, but knowing full well a lot of people won't see them.
e.g. rounded corners. I accept that they won't be rounded in IE.
I use CSS3 as much as I can, which is actually quite often, provided I can get the client to agree to graceful degradation.
Unsurprisingly, if the client doesn't actually use IE themselves, I've
found that my chances of getting them to agree is drastically increased.
I use CSS3. Rounded corners are a great example. Do I use fall back to images for older IE? No, that won't encourage anyone to upgrade and lets face it they expect a worse browsing experience or for the most part have no idea what they are missing out on anyway. There are also easy, time efficient work arounds for older IE such as CSS Pie which works quite well.
I segregate stuff into layout and prettyness. Layout stuff has to work perfectly down to IE7 (and ideally IE6), so at work I still use a class of "last" instead of :last-of-type. (For personal stuff though I don't support IE7 or below).
Prettyness though I do as much CSS3 as possible. If someone is going to view my work with IE7, they don't deserve the nice fonts and animations and gradients, however everyone needs to be able to navigate and use the site effectively.
Yeh, I use rounded corners, gradients and shadows more now. I do wish there weren't browser specific attributes though. It's annoying specifying the same border radius 4 times!
Unless it is a requirement, old IE users can have square corners, flat colours and no fancy text. It's part of their punishment.
Except when it's some IE6 using, non-tech-savvy, potential customer who is underwhelmed by your site and decides to look elsewhere for their web design / development needs. Then it's your punishment.
Highly unlikely scenario, I know. :p
Except when it's some IE6 using, non-tech-savvy, potential customer who is underwhelmed by your site and decides to look elsewhere for their web design / development needs. Then it's your punishment. [...]
Any potential customer that comes to my design agency demanding/expecting a site to be pixel-indentical from Webkit through to IE6 stays a potential customer.
For these people, their money isn't worth the hassle that you're inevitably going to get with them later down the line, whether it's:
- Wanting to micromanage every aspect of the design ['The Photoshop Organ-Grinder']
- Failing to understand why prototyping is important ["How much is it if we leave out the wireframes?"]
- Not supplying content until 2 days before the site is due live [and when it does thud into your inbox, it's paragraph after dense paragraph of stodgy tedious jargon only barely relevant to the site's purpose]
- et-bloody-cetera.
Send them away with a cheery wave.
Gosh, that turned into a bit of a rant, didn't it? Sorry :D
I have been trying to push this with clients for the last year or so and most are receptive.
Rather not have that person as a customer.
It's rather annoying that there is no standard. Having to write the attributes for each browser is a bit of a pain.
I think I'd rather use an image than incorporate all of that code in my styles. I usually just set border radius and moz/webkit ones.
up-to-date safari and chrome browsers don't need the -webkit prefix anymore do they?
