I wanted to upgrade my Canon A70 (digital) to an IS camera with a long focal length lens. I wanted one with RAW (to try my hand at HDR), a reasonably fast lens and low noise levels.
I had hoped that the replacement for the Canon G6, the G7 would have fitted the bill, unfortunately the focal length of the lens is less that I would have liked and it does NOT have RAW. The noise levels seem acceptable.
So, is anyone using the DMC? Are the noise issues as bad as the reviews would have us believe?
Could someone please advise me: In real terms what is the difference between a F2.8 and F2.0? If say (using an old hand held light meter), the ideal shot was FStop 2 at 1/125th of a second, if now the largest aperature is F2.8 what would the speed be? (using a calculator and percentages I make it (and I bet it's wrong) 1/110th of a second?
I've always had Canon Cameras (film/digital) and might consider waiting for G8
