- 18 May 2010
Long shot but here goes, hoping someone has a similar setup that can confirm my theory before I spend £200 on TRVs
I have two rads without TRVs, one in the office and one in the hall near the thermostat.
If I add Hive TRVs to all other rads and set the schedule to frost protection in the day and thermostat to 20C the two rads without TRVs will come on and the Hive TRVs will prevent all other rads from coming on.
If the schedule then changes in the evening for the rads with Hive TRVs to match the thermostat at 20c all of the other rads will function
Is this correct?
What I am doing here is not using the Hive TRVs to call for heat or "heat on demand" but actually using them to prevent the rads they are fitted to from firing up so that the dumb rads in the office and hall way are heating up only.
Thanks
Is this correct?
Thanks
