Anyone using intel for onboard ethernet?
19 Jan 2005
Cambridge
I remember a few years ago there were a lot of problems with the Intel 2.5Gb ethernet chips (i225-v) causing disconnections and slow speeds. A lot of the higher end boards are still using them, particularly the Asus Strix/Crosshair boards, and even some of the newer X870 boards which makes me think it’s probably ok now. Every so often I see another post about it though. Is there still a problem with this?
Mine seems ok
Crosshair viii extreme x570
Might be driver updates have helped the issue
Don't have any other boards using it though
So just a sample of 1
Not really enough to say it's fixed
From what I've seen posted online, I think the problem persists and even the i226-v has issues. But, it doesn't impact all boards and it is mainly a problem with 2.5 Gb operation and not 1Gb.
