The fact you're running the speed test direct from the AP eliminates everything after the AP so perhaps create a new network, move one AP into that network (default settings) and try the speedtest again.
Really weird that it's only your Surface 4's that are a problem. What are the speeds like connection to other brands of AP?
All our other devices connect fine to the AP's at full speed and no high pings or packet loss.
It's a tricky one. I use an MR12 at home for homing working. Created an SSID that just uses my own lan and while the speedtest was fine to the AP (Still only 30mbps) it would have a high ping and drop packets. Connect to my own AP and all is fine.
Done some more reading and there is loads of user complaining still about the surface and the crap wifi with some brands of AP.
Can you check what driver version the wireless is on the ones in your office? The one have here ends with 67.
I have rolled back, reinstalled etc with no joy. It's a pitty as the device is good, but it seems the Wifi is ****e. Whether that down to drivers or hardware who knows!
Not much to bring to this party, except I have the free AP and switch at home and the equivalent in work. They're just wonderful and consistently work. Not something you can generally say about any Wireless AP.
