anyone using or used XFX DD cards?
22 Nov 2010
Kettering
hey guys,
my friend has offered me two XFX HD 7970 DD GHZ edition GPUs for a deal i am really thinking about taking.
im just abit iffy about the coolers running them in Xfire, have any of you guys got a GPU with this cooler? if so theres two things i want to know:
1. is it quiet?
2. are they good coolers?
cheers guys
Tommy has. He didn't get on with it at all I don't think.
From what I have read they aren't the coolest and they aren't the quietest either. They're a budget solution.
At stock there very quite and keep card nice and cool. BF3 never passes 58c
But OC to 1100/1500 and noise level does get quite high anything above 65% is quite loud. But I use gaming headset so noise no issue for me.
Temps once OC BF3 stays around 65c and other games like Tomb Raider/sleeping dogs etc pushes temps higher around 73c
One thing to also think about is make sure the card is the voltage unlocked version, because I had my card since release and they was unlocked, but now when buying they are locked.
If I could go back to release of the 7000 series I would have went with the gigabyte card, But I have zero regrets so far.
Thats after couple rounds bf3. No issue with temps on my card, but noise at 64% is quite loud but using a headset not a issue :D
noise is very important to me and i like to push my GPU's :D
so i should let these cards pass then, as i would run them together
im running a 6990 atm and its really noisy, when i upgrade the card i want the quitest i can get without watercooling
