Anyone using SCCM with DHCP NAP?
26 Nov 2009
Just wondering if any of you guys are using SCCM with DHCP NAP and doing operating system deployments?
We have few issues with doing OSD as the machines are not getting assigned proper DP from SCCM infrastructure (remediation group on the NAP doesn't give out default gateway) so the machines are falling back to central SCCM server for DP files.
Will happily expand on the above but need to know if anyone is doing something similar.
cheers.
Yes and No
I looked at it a couple of years ago. The issue is I guess you are assigning your TS to the unknown computers collection. Since it's unknown to SCCM, chances are it's also unknown to the network
Getting the right NAP policies to work with SCCM is tricky
There are solutions (nothings impossible), but need to know your environment a bit better.
What you could do, is have a workbench dedicated to unknown machine imaging and leave the rest of the network locked down. The minute the device is domain joined, things become much easier.
