- 28 Dec 2009
- Wales
Looking for a new case and wondering if the silencio would be ok for an oc'd i5 build with a gtx 570?
After watching TTL's review on youtube, it seems like the foam is really thick and makes it difficult to squash cables behind the side panel, and also for tall heatsinks?
Good luck with your Define XL
Dont forget to bend your knees when picking it up![]()
That sucks i would have been gutted.
Not very cheap to send back an XL
Fractal are getting a bit of a reputation.Quality control is not quite there yet.
But as long as your happy with the case![]()
