Anyone using the Terratec Cinergy 2400i
18 Sep 2005
I'm very tempted by this card (Terratec Cinergy 2400i - MCE Edition)
- you can get it for just £63 - not bad for a dual tuner solution!
Is anyone here using it? If so are there any known problems/issues? I vaguely remember people mentioning S3 issues or tuning problems.
Thanks
Marc
I'm using it nd it's a nice card however DO NOT install the supplied drivers.
Use the latest ones off the website, if you install the supplied ones you'll have a devil getting it working because the upgrade from supplied to latest doesn't work to well ( I had to re-install XP to upgrade the drivers ), however just going straight to the latest ones and you'll be ok.
