Anyone using TomTom on ios6? GPS problem
30 Dec 2005
Hi all, is anyone using Tom Tom app? I am having GPS issues, previously I had it on my 4S 5.1 without any problems but now on my iPhone 5 6.1.2 I cant get a decent GPS lock on it :confused:
Pick up is fine when in the car stationary but as soon as you start moving "Poor GPS..."
anyone else got this issue :confused:
I have the exact same issue. The app (UK & ROI) was running fine on both my 3g and 4s on ios 5.1.1 but when I upgraded to 6.1 and beyond it has been exactly as you described. I've posted on the tomtom forums with no luck and the apple forums too. I've since binned the app and moved to Copilot live ultimate - it works flawlessly (as does every other GPS dependant app I run).
Cheers, I liked the app but seems like TomTom and/or Apple areny going to fix anything. Used Waze and CoPilot which seem to work right from the off and shall be sticking with Waze for now.
