Anyone with a newish Renault? Dumb question...
24 Sep 2005
Middlesbrough
How do you change the clock on this french ****?
P.S - It's a Kangoo van.
Also it's a lease vehicle and I don't have the manual otherwise I'd look :p
So apparently there's 2 holes for a ballpoint even though I've felt all around the dash and can't feel anything like that? :(
Why on earth isn't there a little button poking out which lets you adjust the clock like most other manufacturers, or let me change it in the menu. Stupid french van :(
Did you read the instructions on joes link? Depending on the equipment level, there are either buttons next to the clock, or you have to use the stalk controls to set the clock through the menu.
I did.
But I don't have buttons either side of the actual clock, nor can I control the head unit from the stalk. (Only have skip/volume/telephone controls)
I'll do some further investigation tomorrow when it's daylight and see if I can find a pinhole somewhere.
