I use a 4 port USB hub and it works fineim getting mine on thursday, Does any 1 know if a unpowered usb hub works as i have the 40gig and loast the adaptor. ?
Cheers Phemo, just what i was after![]()
EDIT: Would you be able to check how long the feet are aswell if its no problem?
I have little room in my room.
Ta
No worries. The feet are about 48cm from the furthest back point to the very front if that's what you mean?
Cheers buddy. Although there not gonna fit in my room lol![]()
You can put the drums on a desk. You plug the drum pad straight onto the feet and they just sit on your desk.
Does that help?
Cheers tho!
The foot pedal takes up hardly any more room than the kit itself. It just sits nicely under the drums and only protrudes a little.Nope lolCheers tho!
My room is square and i have a bed in the middle against the back wall, so imagine about half a meter walk way around the bed. I'm hoping i can push my bed back a few cm's and my tv unit a few cm's to makes 48cm-50cm gap, that way i can sit on the end of my bed
I will post pics when rockband arrives so you can all laugh at me
EDIT: Just realised need more room for the footpedal, i give up
