Anyone with techie knowledge of British Gas Remote Heating system?
itm
itm
22 Feb 2011
I've just ordered a British Gas Remote Heating Control installation, and was wondering if anyone knew anything about TCP/IP configuration options for it?
I'm guessing that the British Gas Hub will be installed on TCP port 80 for web access, but as I run a web server on my home server I'd prefer the British Gas Hub to use another port - e.g. 8080 or something like that. Does anyone know if that's possible??
Just forward another port to 80 on that.. Can't see an issue here.
They're public-facing websites so need to come in on port 80. I could investigate filtering/forwarding to the hub from my existing web server (IIS) but suspect that it'll open a can of worms.
The cost was £229 - would have been £199 if I'd been a BG customer.
what he means is put port 8080 on your router to forward to 80 internally on the BG stuff. Externally you put http://homeip:8080 but the BG thing doesnt know that.
Why does it matter if they are both on port 80??
Hi, How did you resolve this?
In the end there was nothing to resolve. The web application which controls the Remote Heating functionality (now Hive) is actually hosted on the supplier's servers, not the customer's. The supplier's servers then communicate directly with a receiver which you plug into your broadband router.
