Hi there
Owned a 4.7
Looks and Sound - Totalling amazing stock, just pull fuse 22.
Handling - Steering feel good, handling better than some say, you do have to grab it by the neck but not bad, but it feels heavy and is heavy.
Performance - More than enough to enjoy on the road, its not quick by modern standards but you can enjoy all the power and for longer, good fun car, but a modern hyper hatch, GRY, A35, S3, Golf R is quicker but by comparison none of those come close to the event and occasion drive wise Aston will offer.
Bad points: Speed shift auto is terrible, the manual is the one to get and as a manual its not great either, bit like stirring porridge and a very heavy clutch, but once you get used to it then it is actually OK, but the initial drive can be a bit damn this aint no Porsche or Honda manual.
Reliability: Never had an issue, got it on like 23k miles, gave it to a family member on 30k plus, shortly afterwards its clutch failed and I think the bill for everything, clutch, flywheel, labour was not much change from 4-5k but otherwise reliable.
Get a 4.7 Manual, if funds allow try to buy one from Aston with a Timeless warranty for peace of mind.
