I've had this chip for 3 years now, really feeling the upgrade vibe but im trying to convince myself that it's even worth the effort... (or the £650).
What i'm running..
Intel Core 2 Quad Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz
Gigabyte GA-P35-DS3R (Socket 775) PCI-Express DDR2 Motherboard
Nvidia GTX275 (more recent upgrade!)
Zalman CNPS9700-NT nVidia Tritium CPU Cooler
G.Skill 4GB DDR2 PQ PC2-8000C5 (2x2GB) CAS5 Dual Channel Kit
plus GeIL 2GB (2x1GB) DDR2 PC2-6400C4 800MHz Ultra Low Latency Dual Channel
The ram will seem a little odd, i originally intended to replace the original 2Gb set for the 4GB set but i stuck them all in and everything still works perfectly. The system is currently overclock from 2.4 to a lowly 3.2Ghz. I've never had any real luck getting any kind of decent overclock but that's probably because i suck! (pre extra ram).
This is what i'm thinking of getting...
My current case is an 8 year old Cooler master 201 which i love but has seen better days.
(the case, and note the PSU is now inside after some Dremel action!)
Give your opinions please!
p.s case will be needed as no room for a 120mm fan (for H50) in the old girl as it was all 80mm then.
What i'm running..
