anything better than 7970
he is the man to ask as he now looks to have the 680 in stock he will test the cards side by side and give us true results.
You don't need to wait for Gibbo, I can already tell you.
No. There is absolutely and utterly no reason whatsoever on this earth upon which we reside that it's worth getting rid of your 7970 and buying a 680.
Not unless you have upgraditis and can't control yourself.
Put simply there is nothing a 680 can do that the 7970 can't. So unless you are obsessed with numbers I would just relax and enjoy your card.
Because if you don't then man, you have some expensive lessons coming up.
AMD are not done with Southern Islands. Give it a few weeks and Tenerife or a heavily overclocked 7970 will be with us and once again you will be playing the catch up game.
GTX680 from an OCN member
http://www.guru3d.com/news/geforce-gtx-680-sli-performance-uncovered/
Looks to be a little over hyped.
i3 CPU
32Bit OS
Major fail.
