- 9 May 2009
Hi all
wounder if u can help I bought a s-flex 1200rpm fan for my case it's exellent but one thing there is a slight noise comming trom the motor I have read that this s normal for this fan but to be honest I don't like it even the antec tri set to low sound better than this.
So the question is is there a better fan with the same spec less this humming noise from the fans motor and silent
thanks
thanks
