Anything better than Peer Guardian?
basmic said:
Let me put it another way - nobody has knocked at my door or sent me a letter about my file sharing activities, out of nearly 7 years. :D
My ISP back in the states threatened to give me the boot if i didn't stop downloading torrents as apparently NBC called them about my "activities".
Started using PG and never got another complaint. Also the guy working for my ISP told me to use Frostwire as it's *** safest P2P and I checked it out but downloads are slow and variety is limited.
IAmATeaf said:
Does PG2 actually protect you then?
I was led to believe that the answer was not as the info that's gathered it what IP addresses are downloading and to do this they can simply connect to the tracker.
PG2 will stop a known IP address or range of addresses from connecting to your PC but the evidence that you were downloading based upon your IP address will still be there.
Unless they connect to you, they can't prove that you actually transferred any data.
begbo said:
p2p is for n00bs anyway! Rapidshare is the way forward! ;)
Finally another person who shares this view. Far faster and if you join a private forum its easy to find links to all sorts of legal content. :D
are wide varieties of files made public as fast as places like torrentspy?
Not as wide, but there is still huge amounts of stuff, including some stuff which I have been unable to find on torrents. And new stuff usually has a day or so delay compared with torrents.
Peerguardian is a gem but its not just the program that takes the glory, its actually the block lists that do the business.
When PG loads a corrupt/empty list, its not so good hence why you need to check the lists after an update.
There are several programs out there similar to PG but at the end of the day they all use the same blocklists.
PG is one step of protection but you need to implement the blocklists into your firewall to block you from accessing them, not just them accessing you.
